Valve stem oil seals
  • joshjake233
16 Sep 2014 18:56 #124304 by joshjake233
Valve stem oil seals was created by joshjake233
Has anyone changed the valve stem oil seals on their Jimny.
Mines smoking on start up but its not the PCV valve.
Just wondering if its something i can do myself?
Its a 1998 model.
  • helijohn
16 Sep 2014 22:00 #124331 by helijohn
Replied by helijohn on topic Valve stem oil seals
joshjake233 wrote: Has anyone changed the valve stem oil seals on their Jimny.
Its a 1998 model.
I poured this in and it worked.
  • jimnydms
16 Sep 2014 22:01 #124332 by jimnydms
Replied by jimnydms on topic Re:Valve stem oil seals
I have 1999 with exactley
The same thing and also a bit sluggish, I'm in 2 minds whether to do a re build or engine upgrade just
So much work on a g16 for nt that much extra
  • joshjake233
24 Sep 2014 12:22 #124956 by joshjake233
Replied by joshjake233 on topic Valve stem oil seals
Thanks for the suggestion but already tried it.It made a difference but not big enough! :(
  • Valleymills
07 Aug 2020 07:33 #226197 by Valleymills
Replied by Valleymills on topic Valve stem oil seals
I have this problem on a 1999. Are the seals suitable for changing with the head on.
07 Aug 2020 10:54 #226219 by Scimike
Replied by Scimike on topic Valve stem oil seals
Not directly related to the Jimny engine, but I have been told that you can do it so long as you can hold the valve up. Reported methods are TDC the cylinder with string in the bore, or adapted plug to allow you to use compressed air to hold it closed.
Do they work?
I don't know, I have always opted to remove the head and give it a full service while it is off. This way my new seals are working with a decoked head, lapped valves and new head gasket. Its only a few more bolts once the cam / rocker is out of the way.
You could try and if it goes wrong you have a need to remove the head. :laugh: :laugh:
Mike
Time to create page: 0.156 seconds
