Valve stem oil seals
- Valleymills
07 Aug 2020 21:10 #226283
by Valleymills
Replied by Valleymills on topic Valve stem oil seals
Havent noticed any but will check
- Roger Fairclough
- Thank you received: 225
07 Aug 2020 21:29 #226285
by Roger Fairclough
Replied by Roger Fairclough on topic Valve stem oil seals
I don't know the specific details of your engine but it is normal for the designer to incorporate traps so that on initial start up there is enough oil to lubricate, in your case, the valve stems. It can take up to 30 seconds for the oil to circulate throughout the engine and the cam box is last to get it. It is quite possible that the seals are slightly worn and on initial start up a small amount of oil has got past the seal lip and it is that that gets burnt. If the amount that the engine burns is acceptable to you, say a pint in 1000 miles, then I would leave well alone.
Roger
Roger
- Valleymills
07 Aug 2020 21:31 #226286
by Valleymills
Thanks
07 Aug 2020 21:50 #226287
Replied by helijohn on topic Valve stem oil seals
If the Jimny is a keeper then I'd get it done.
Time to create page: 0.247 seconds
