1.8 issue
- Jimny_Aus
01 Aug 2014 23:38 #121224
by Jimny_Aus
Replied by Jimny_Aus on topic 1.8 issue
have a chat with Zuknutter..... i though he sorted his out...
02 Aug 2014 11:49 #121235
by facade
Are you using the 1.8 injectors, or just the larger fuel rail?
I recall that the injectors are a different colour and deliver more fuel per pulse on the bigger engines, then the jimmny ecu can cope.
02 Aug 2014 12:21 #121242
by Rhinoman
The Jimny and Liana FPRs give the same pressure, I'm pretty sure that you'll find that they all give the same pressure.
jtayl153 wrote: i think i may have come up with a solution that doesnt mean remapping the ECU. I'm currently using the Jimny fuel regulator
i'm going to swap and use the liana fuel regulator and see if that makes a difference
I'veheard that the liana fuel regulator give too much fuel to the motor so i might need to chase 1 from a suzuki swift.
- auchenblae
- Elite Member
- Thank you received: 25
02 Aug 2014 19:34 #121255
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic 1.8 issue
I cannot see how a timing/mixture map for a 1.3 engine will suit a 1.8 engine.
The problem with manufacturers is that they can change the wiring connections between the same car and different years to the ECU, the MX5 being an example.
So you cannot always change them about.
Does the Jimny ecu allow itself to be remap'd?
Therefore I would be surprised if you can change them over between different cars but you never know.
I would think you will need a remap but that may be a long and expensive road to travel down or it may be easy.
eddie
eddie
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
02 Aug 2014 22:07 #121264
by Rhinoman
Yes, it can be done through the diagnostic port if you know the 'password' or through the AUD interface on the PCB.
auchenblae wrote: Does the Jimny ecu allow itself to be remap'd?
Time to create page: 0.090 seconds
