1.8 issue
  • gus2000
02 Aug 2014 22:12 - 02 Aug 2014 22:13 #121265 by gus2000
Replied by gus2000 on topic 1.8 issue
facade wrote: Are you using the 1.8 injectors, or just the larger fuel rail?
I recall that the injectors are a different colour and deliver more fuel per pulse on the bigger engines, then the jimmny ecu can cope.
If you use a 1.8 injectors (as it is correct :) ) is possible that the jimny fuel pump does not supply them reach and pressure decreases.
check the injection pressure (with a adecuate manometer) in wide open throttle (WOT) and the maximum number of engine rpm conditions (in the dinamometer or highway)
The fuel pressure must be maintained at the levels indicated by the Suzuki 1.8 engine
Otherwise install a high flow fuel pump (the jimny fuel pump can be very small for 1.8 fuel demand)
gustavo
Last edit: 02 Aug 2014 22:13 by gus2000. Reason: drafting error
Time to create page: 0.062 seconds
