Cigarette lighter socket not working
  • minibbb
30 Jul 2014 19:47 #121067 by minibbb
Replied by minibbb on topic Re:Cigarette lighter socket not working
Halford wrote: just use blue bullet connectors to connect the wires to the new socket and try it, if it don't work then simply swap the wires over and it'll work
Cheers mate will give it a try. The socket came- looks crap!
Can't see how this is for a jimny, the plastic but doesn't seem to come off so can't see how I can get it in its hole!
  • helijohn
30 Jul 2014 21:08 #121086 by helijohn
Replied by helijohn on topic Cigarette lighter socket not working
These fitments are so fiddly they are a pain. Often a bayonet or clip fitment and only one outlet!! Pain, pain pain.
31 Jul 2014 03:20 #121097 by Halford
Guessing the black end cap screws off then you pop the green body through the hole from the rear of the fascia then screw the cap back on. The wires that are already on are just to illuminate the green body so you'll need some correct sized bayonet crimps to make up leads
  • helijohn
31 Jul 2014 08:17 #121110 by helijohn
Halford wrote: Guessing the black end cap screws off then you pop the green body through the hole from the rear of the fascia then screw the cap back on. The wires that are already on are just to illuminate the green body so you'll need some correct sized bayonet crimps to make up leads
I am guessing too regarding that one in the pic but most of the OE ones are pushed in from the front and either stay put with a bayonet action, have a clip action or are retained by a case that screws on from the back. One thing is for sure, all the ones I have messed with have been different according to the maker and never can I find instructions anywhere to remove these things from motors. Pain, pain, pain.
On this one it looks to me like the green casing releases from the body by pressing clips, then one puts the casing behind the hole in the dash and pushes the body in from the outside/front whereby it will snap into place. Pain, pain, pain.
  • minibbb
01 Aug 2014 14:39 #121194 by minibbb
Well... Turned out the socket I bought was utter crap so discarded it and went with this one instead
Mate had it kicking around in the garage and it screwed on nicely. Means I can get out lamping now :)
Thanks again for the help everyone!
  • helijohn
01 Aug 2014 14:52 #121195 by helijohn
Replied by helijohn on topic Re:Cigarette lighter socket not working
minibbb wrote: Well... Turned out the socket I bought was utter crap so discarded it and went with this one instead
Nice but more to the point, got any details to tell us about the wiring it in??
Time to create page: 0.103 seconds
