Cigarette lighter socket not working
- minibbb
12 years 3 months ago #120787
by minibbb
Cigarette lighter socket not working was created by minibbb
Afternoon gents, the lighter socket in my jimny isn't working. Would this likely be a fuse or would I need to swap out the socket?
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
12 years 3 months ago #120788
by funkyjimny
Replied by funkyjimny on topic Cigarette lighter socket not working
Nearly always the fuse, there are some odd plugs that sometimes don't mate with the socket correctly so check a couple of plug in things. Fuse box is under dash near drivers right knee, careful how you take the cover off as it has the icons on it to tell you which fuse is which
Gary
Gary
The following user(s) said Thank You: minibbb
- minibbb
12 years 3 months ago #120791
by minibbb
Replied by minibbb on topic Re:Cigarette lighter socket not working
Fuse is fine- wire all intact. Ill go hold of another plug to try cheers mate!
12 years 3 months ago #120797
by Halford
Replied by Halford on topic Cigarette lighter socket not working
sure it's not the case, but it does only work with ignition on or key switched to acc :pinch:
has it ever worked ?
12 years 3 months ago #120821
Did you test it with a probe light or meter etc. for power? On some other makes there is a wire link on the end of the socket which can melt.
Replied by helijohn on topic Cigarette lighter socket not working
minibbb wrote: Afternoon gents, the lighter socket in my jimny isn't working. Would this likely be a fuse or would I need to swap out the socket?
12 years 3 months ago #120836
Replied by mlines on topic Cigarette lighter socket not working
The "plug" can easily fall off the back of the cigar lighter socket. Reach up the back of the socked and see if its connected
Time to create page: 0.104 seconds
