Bottom Crank Pulley?
12 years 4 months ago #119468 by Casey
Bottom Crank Pulley? was created by Casey
Hi
Hoping someone can give me a steer on this.
On the way home yesterday a nasty rattling noise started coming from the front of the car. When I lifted the bonnet, I could tell it was coming from somewhere around the belt.
Took it in to the local garage today and he reckons the bottom crank pulley is what's causing the noise and advised not to drive it. Gave me some spiel about there could be 2 pulleys that are causing the problem, but will replace this one first to check.
Anyway, bottom line is he wants £260 plus VAT. This seems steep if he's only changing one pulley. Wouldn't it be best to be changing the lot and the belt at the same time? Just looking for some idea of what I should be paying as I haven't a clue.
By the way it's a 2005 1.3 JLX DOHC.
  • markyp2000
12 years 4 months ago #119479 by markyp2000
Replied by markyp2000 on topic Bottom Crank Pulley?
Dont think the pully are cheap ask in the wanted section for a second hand one
12 years 4 months ago #119482 by j999pre
Replied by j999pre on topic Bottom Crank Pulley?
Changing that pulley is quite common on the dohc. Ps and alty belts off then the really tight 17mm then the pulley can come off
Grey pick up Jimny
  • trialbiker
12 years 4 months ago #119484 by trialbiker
Replied by trialbiker on topic Bottom Crank Pulley?
I changed the bottom pulley on mine last year , also a 2005. The pulley itself was around £160, common to go as the rubber damper in the middle breaks. If you took the belts off normally the outside of the pulley just falls off. The fun part comes trying to get the middle off the end of the crank.
The rattle you can hear is where the pulley is moving backwards and tapping on the engine.
12 years 4 months ago #119493 by Casey
Replied by Casey on topic Bottom Crank Pulley?
Thanks for your responses. I guess if the pulley costs £160 the overall price isn't all that bad.
Cheers.
12 years 4 months ago #119509 by Busta
Replied by Busta on topic Bottom Crank Pulley?
If he thinks it could be 1 of 2 pulleys, just make sure he does the crank pulley first! I'm not sure which other pulley he thinks it could be though.
Time to create page: 0.108 seconds
