Fuel gauge stuck half way
  • bigpantz
20 May 2014 17:37 - 20 May 2014 17:40 #115860 by bigpantz
Replied by bigpantz on topic Fuel gauge stuck half way
I topped up the fuel to see what sort of effect it would have on my gauge and its now stuck on full.
I have done a bit of reading and apparently there are two coils one which pull the gauge to full and one that pulls it to empty. I reckon my gauge has lost an earth . probably on the coil that pulls it to empty..
simple enough circuit probably awkward to get behind the dash
Last edit: 20 May 2014 17:40 by bigpantz.
20 May 2014 19:14 #115887 by Halford
Replied by Halford on topic Fuel gauge stuck half way
good luck,
but now that you've topped up the tank ...... did the filler pump click off ?
simply set your trip and refill the tank when the tank reaches 200 or 210 miles
and you'll never run out ....
  • steffan
20 May 2014 19:24 #115888 by steffan
Replied by steffan on topic Fuel gauge stuck half way
Halford wrote: good luck,
I would lol my jimny isant exactly economical with my lead right foot
  • bigpantz
21 May 2014 19:01 #115949 by bigpantz
Still baffled but I have made a little progress.
The connector that's showed in the wiring diagram is in the passenger footwell, with this unplugged the gauge drops back to zero . (it didn't drop back to zero when I disconnected the battery)???
The measured voltage on the yellow/red cable is 11.25 volts.
so far its looking like the sender unit. or is it .
  • Yellostreak
22 May 2014 13:26 - 22 May 2014 13:28 #116015 by Yellostreak
Replied by Yellostreak on topic Fuel gauge stuck half way
bigpantz wrote: Still baffled but I have made a little progress.
right here goes..
the red/yellow is the +ve feed into the circuit.. the transistor and two resistors above the blackline are to provide a regulated voltage else each time the engine laboured your gauge would go down and each time you revved it would go up.. 11.25V seems high since in theory the battery voltage could be lower than that at some points.. the connector [E23] removes the supply so this is why the gauge drops to zero. if this guage has two coils then its unique, all that I have seen are single coil meters.
Question: does the 11.25v change with engine rev? if it does the voltage regualtor is screwed and that will be the reason you are 'half full'.
Last edit: 22 May 2014 13:28 by Yellostreak.
  • bigpantz
22 May 2014 17:25 - 22 May 2014 18:05 #116029 by bigpantz
yellow streak
i had it in my mind that the feed came in on the black +orange. might be easier if i printed out the pages instead of trying to look at them on screen . studying the diagram you can see blue/black from ignition key lg1. feeding 10Afuse
then feeding the yellow +red..
still trying to figure out why the gauge doesn't drop when you disconnect the battery??
But it drops when you disconnect the connector?? Maybe a cable chafed on the body work ??
Will have more time the weekend. will persevere . This is the only thing that doesn't work on my jim jimny
Gary
Last edit: 22 May 2014 18:05 by bigpantz. Reason: spelling error
Time to create page: 2.126 seconds
