4x4 appears to be working but light flashing
  • dandogman
  • Visitor
  • Visitor
10 May 2014 21:44 #114782 by dandogman
Replied by dandogman on topic 4x4 appears to be working but light flashing
ne-crock wrote: it might be the filling of the pipes is passing causing the light to flash but if you had manual hubs fitted i wouldnt bother about the flashing light, mine flashes with the manual hubs,
also your problem with the oil is your king pin bearings are gone and need replacing,
you need this
www.test.bigjimny.com/store/index.php?_a=product&product_id=6
and this is how you do it,
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
So it's not a problem and 4x4 is working fine and I can ignore the light?
So how should I change into 4x4 mode - do I just use the hub switches or the inside stick too?
  • ne-crock
  • Visitor
  • Visitor
10 May 2014 21:47 #114783 by ne-crock
Replied by ne-crock on topic 4x4 appears to be working but light flashing
to put it in 4wd you have to have both the lever inside in 4wd and the switches on both hubs in 4wd,
normally its all controlled from the lever as the hubs are vaccum operated, but these are renound for failing and leaving you in a sticky situation, thats why people fit manual hubs as you can physically select the hub to be engaged and then you select 4wd inside to engage the drive in the transfer box
  • jonesyba420
  • Visitor
  • Visitor
11 May 2014 05:32 #114802 by jonesyba420
Replied by jonesyba420 on topic 4x4 appears to be working but light flashing
If your a regular offroader most seem to leave manual hubs in 4x4 and just use the lever.
I personally couldnt handle staring at a flashing light everytime I use 4wd.
I think the main reason vacum hubs fail is the pipes perish, your pipes could be split and leaking anywhere along their length. I think its probably best to block them at the vacum tank in the wing.
  • markyp2000
  • Visitor
  • Visitor
11 May 2014 09:23 #114815 by markyp2000
Replied by markyp2000 on topic 4x4 appears to be working but light flashing
dandogman wrote:
markyp2000 wrote: You have manual free wheeling hubs thats why the light flashes you have to turn then to 4x4 then select 4wd on you tranferbox
Just gone out and done this - light still flashes.
it will keep flashing because you have manual hubs just take the bulb out
Time to create page: 0.130 seconds
