4x4 appears to be working but light flashing
- dandogman
- Visitor
10 May 2014 14:52 #114724
by dandogman
4x4 appears to be working but light flashing was created by dandogman
Tried 4x4 mode on off road today, appears to work but light on dash flashes which I read in the manual means it isn't working, but I think it does work (does that make sense?)
Also - noticed on front wheels has a little switch from 2 to 4 wheel drive on each side - do I need to switch these on too?
Any thoughts?
Any thoughts?
- markyp2000
- Visitor
10 May 2014 15:18 #114728
by markyp2000
Replied by markyp2000 on topic 4x4 appears to be working but light flashing
You have manual free wheeling hubs thats why the light flashes you have to turn then to 4x4 then select 4wd on you tranferbox
- dandogman
- Visitor
10 May 2014 17:55 #114742
by dandogman
Just gone out and done this - light still flashes.
Replied by dandogman on topic 4x4 appears to be working but light flashing
markyp2000 wrote: You have manual free wheeling hubs thats why the light flashes you have to turn then to 4x4 then select 4wd on you tranferbox
10 May 2014 19:29 #114765
by Rhinoman
Replied by Rhinoman on topic 4x4 appears to be working but light flashing
It may well flash, you need to block off the vacuum pipe, have a look through the technical articles for the details
- dandogman
- Visitor
10 May 2014 19:31 #114766
by dandogman
- ne-crock
- Visitor
10 May 2014 20:14 #114771
by ne-crock
Replied by ne-crock on topic 4x4 appears to be working but light flashing
it might be the filling of the pipes is passing causing the light to flash but if you had manual hubs fitted i wouldnt bother about the flashing light, mine flashes with the manual hubs,
also your problem with the oil is your king pin bearings are gone and need replacing,
you need this
www.test.bigjimny.com/store/index.php?_a=product&product_id=6
and this is how you do it,
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
you need this
Time to create page: 0.132 seconds
