4x4 appears to be working but light flashing
  • dandogman
  • Visitor
  • Visitor
10 May 2014 14:52 #114724 by dandogman
Tried 4x4 mode on off road today, appears to work but light on dash flashes which I read in the manual means it isn't working, but I think it does work (does that make sense?)
Also - noticed on front wheels has a little switch from 2 to 4 wheel drive on each side - do I need to switch these on too?
Any thoughts?
  • markyp2000
  • Visitor
  • Visitor
10 May 2014 15:18 #114728 by markyp2000
Replied by markyp2000 on topic 4x4 appears to be working but light flashing
You have manual free wheeling hubs thats why the light flashes you have to turn then to 4x4 then select 4wd on you tranferbox
  • dandogman
  • Visitor
  • Visitor
10 May 2014 17:55 #114742 by dandogman
Replied by dandogman on topic 4x4 appears to be working but light flashing
markyp2000 wrote: You have manual free wheeling hubs thats why the light flashes you have to turn then to 4x4 then select 4wd on you tranferbox
Just gone out and done this - light still flashes.
10 May 2014 19:29 #114765 by Rhinoman
It may well flash, you need to block off the vacuum pipe, have a look through the technical articles for the details
  • dandogman
  • Visitor
  • Visitor
10 May 2014 19:31 #114766 by dandogman
Just took some pics - looks like cable has been cut and filled
And on a different subject - this didn't look good either
  • ne-crock
  • Visitor
  • Visitor
10 May 2014 20:14 #114771 by ne-crock
Replied by ne-crock on topic 4x4 appears to be working but light flashing
it might be the filling of the pipes is passing causing the light to flash but if you had manual hubs fitted i wouldnt bother about the flashing light, mine flashes with the manual hubs,
also your problem with the oil is your king pin bearings are gone and need replacing,
you need this
www.test.bigjimny.com/store/index.php?_a=product&product_id=6
and this is how you do it,
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
  • dandogman
  • Visitor
  • Visitor
10 May 2014 21:44 #114782 by dandogman
ne-crock wrote: it might be the filling of the pipes is passing causing the light to flash but if you had manual hubs fitted i wouldnt bother about the flashing light, mine flashes with the manual hubs,
you need this
So it's not a problem and 4x4 is working fine and I can ignore the light?
So how should I change into 4x4 mode - do I just use the hub switches or the inside stick too?
  • ne-crock
  • Visitor
  • Visitor
10 May 2014 21:47 #114783 by ne-crock
to put it in 4wd you have to have both the lever inside in 4wd and the switches on both hubs in 4wd,
normally its all controlled from the lever as the hubs are vaccum operated, but these are renound for failing and leaving you in a sticky situation, thats why people fit manual hubs as you can physically select the hub to be engaged and then you select 4wd inside to engage the drive in the transfer box
  • jonesyba420
  • Visitor
  • Visitor
11 May 2014 05:32 #114802 by jonesyba420
Replied by jonesyba420 on topic 4x4 appears to be working but light flashing
If your a regular offroader most seem to leave manual hubs in 4x4 and just use the lever.
I personally couldnt handle staring at a flashing light everytime I use 4wd.
I think the main reason vacum hubs fail is the pipes perish, your pipes could be split and leaking anywhere along their length. I think its probably best to block them at the vacum tank in the wing.
  • markyp2000
  • Visitor
  • Visitor
11 May 2014 09:23 #114815 by markyp2000
it will keep flashing because you have manual hubs just take the bulb out
Time to create page: 0.166 seconds
