Using water
  • markyp2000
12 years 6 months ago #113708 by markyp2000
Replied by markyp2000 on topic Using water
Id say you have a leak some where get a pressure test done on it
  • Tasscorp
12 years 6 months ago - 12 years 6 months ago #113732 by Tasscorp
Replied by Tasscorp on topic Using water
Have you checked the external radiator reservoir ? If the level is going up then your radiator cap should be replaced, it's not holding pressure and you water is going out to the reservoir.
"Si no entiende lo que escribí, es por que lo hice desde mi iPhone"
Last edit: 12 years 6 months ago by Tasscorp.
  • nealey
12 years 6 months ago #113736 by nealey
Replied by nealey on topic Re:Using water
Tasscorp wrote: Have you checked the external radiator reservoir ? If the level is going up then your radiator cup should be replaced, it's not holding pressure and you water is going out to the reservoir.
I've put a new rad cap on mate, thanks
  • Tasscorp
12 years 6 months ago #113756 by Tasscorp
Replied by Tasscorp on topic Re:Using water
Hope that will do the trick. Just be sure to buy the oem one or a good quality equivalent with 16psi or 1.1p specs
  • trextr7monkey
12 years 6 months ago #113919 by trextr7monkey
Replied by trextr7monkey on topic Re:Using water
Pop in some K seal usually takes care of minor losses like that
atb
mike
12 years 6 months ago #113922 by Halford
Replied by Halford on topic Re:Using water
trextr7monkey wrote: Pop in some K seal usually takes care of minor losses like that
atb
mike
you still here Mike,
did you sell the Daughter's Jimny ?
Time to create page: 0.108 seconds
