Using water
  • nealey
12 years 6 months ago #113693 by nealey
Using water was created by nealey
My jimny is using water, not a great amount. But theres no leaks, THE oils clean etc. Any ideas, thanks..
12 years 6 months ago #113695 by Busta
Replied by Busta on topic Using water
Do you get any white smoke on start-up? Could be the early signs of the head gasket going.
  • nealey
12 years 6 months ago #113696 by nealey
Replied by nealey on topic Using water
No mate, I aint noticed anything, cheers..
  • markyp2000
12 years 6 months ago #113701 by markyp2000
Replied by markyp2000 on topic Using water
Try and get a sniffer test done on the cooling system it picks up exhaust gases in the coolent also it may be leaking but not when its hot but as its cooling by the time you see it in the morning its dryed up what engine do you have
  • Wiltec17
12 years 6 months ago #113702 by Wiltec17
Replied by Wiltec17 on topic Using water
Pop the plugs out and see if one is cleaner than the others. Sometimes the case when burning coolant. Double check the connections at the pipes, and check all over the rad for signs of leak, either a damp patch or crusting, can be hard to see especially if it's in a hidden area.
  • nealey
12 years 6 months ago #113705 by nealey
markyp2000 wrote: Try and get a sniffer test done on the cooling system it picks up exhaust gases in the coolent also it may be leaking but not when its hot but as its cooling by the time you see it in the morning its dryed up what engine do you have
Hello mate, its the vvt engine. I some times smell anti freeze when in queuing traffic with my window down.
Time to create page: 0.110 seconds
