gearbox 2
  • zukenutter
01 May 2014 11:23 #113880 by zukenutter
Replied by zukenutter on topic Re:gearbox 2
I have a gearbox from a series 2 Jimny which had leaked badly since not long after fitting. Recently I pulled the box to replace the thrust bearing and found the leak while it was out. As mentioned in a previous post there's a rubber plug that gets blown out. I fitted a 'at' junction in it and plumbed it into the breather line.
  • gilburton
05 May 2014 09:02 #114177 by gilburton
Replied by gilburton on topic gearbox 2
If it's a VVT do a search for VVT gearbox as they had problems!!
07 May 2014 13:26 #114373 by kirkynut
Replied by kirkynut on topic gearbox 2
I think from the link Façade posted that the part number for the bung is 09250-10006G.
Mine seems to have a weep from somewhere above that is not engine oil, so I wonder if mine has perished a bit and is allowing it to weep. It started when I replaced the reversing switch so I attributed it to perhaps a bad seal on that but with this knowledge perhaps I disturbed the bung.
I'll see if I can get a mirror up there and have a look see.
  • zukenutter
09 Jun 2014 11:56 #117466 by zukenutter
zukenutter wrote: I have a gearbox from a series 2 Jimny which had leaked badly since not long after fitting. Recently I pulled the box to replace the thrust bearing and found the leak while it was out. As mentioned in a previous post there's a rubber plug that gets blown out. I fitted a 'T' junction in it and plumbed it into the breather line.
Just thought I'd follow up on this with some more info based on recent experience.
The "T" junction I used to plug the hole and plumb into the existing breather extension line turned out to be a bad idea. Because the hole is lower than the breather and level with the selector shafts it was drawing oil and creating a vacuum lock which would draw more oil once the box got hot and the pressure grew. Ended up running the box on way too little oil on a few occasions, long story short I had to pay a visit to a breaker to get a replacement, not to mention it made a hell of a mess at the other end of the breather hose.
After this experience I think that if you run a hose off the breather you should ensure it stays higher than the breather and continually run uphill to ensure oil vapour doesn't collect in any low point of the hose creating back pressure which would possibly blow out the rubber plug. Likewise a blockage of the factory breather would probably also blow it out.
Time to create page: 0.090 seconds
