gearbox 2
  • gipcyan bill
12 years 7 months ago #111774 by gipcyan bill
gearbox 2 was created by gipcyan bill
why is our lasses gearbox covered in oil?
is there a seal that goes
do i get rear engine and front gearbox seal and just see what happens when i split them to have a look
cheers
  • Wiltec17
12 years 7 months ago #111779 by Wiltec17
Replied by Wiltec17 on topic gearbox 2
Is it definatly gearbox oil? Not questioning your judgement, just wasn't clear to me in the post. Mine has oil on from rocker cover gasket, extremely minor leak on mine and next to no oil loss, but looks a mess on the box.
  • Dave cc
12 years 7 months ago #111784 by Dave cc
Replied by Dave cc on topic gearbox 2
Unusual for front gearbox seal to leak rear crankshaft oil seal a possibility depends if its gearbox or engine oil the smell of the oil will tell you gearbox oil stinks other possibilities is rocker cover head gasket or a multitude of other places on the engine might be worth a god degrease then start looking from scratch
  • markyp2000
12 years 7 months ago #111810 by markyp2000
Replied by markyp2000 on topic gearbox 2
If it has a single cam engine there is a seal on the housing that the cam sensor goes in that covers the end of the cam shaft
12 years 7 months ago #111826 by facade
Replied by facade on topic gearbox 2
There is a post on here about there being a rubber plug in a hole by the selector shafts, right at the top of the gearbox that goes missing and gear oil pours out.
www.bigjimny.com/index.php/forum/7-jimny...g13bb-gearbox#107738
If it is gear oil, worth a look
The following user(s) said Thank You: gipcyan bill
  • gipcyan bill
12 years 7 months ago #111849 by gipcyan bill
Replied by gipcyan bill on topic gearbox 2
lol
thanks lads,so it could be coming out of anywhere then :(
ill give it a pressure wash at the weekend then pop it over the pit see if i can trace it
for the price of some seals and if it is in a million bits i don't mind changing them
may even be worthwhile doing the clutch as there seems to be loads of posts about you guys going thru them
Time to create page: 0.092 seconds
