Grease or oil? Help please!
05 Apr 2014 14:48 #111323
by Casey
Grease or oil? Help please! was created by Casey
Hi
I'm new to doing my own mechanics so am looking for some help.
I decided to fit a steering damper today and it was the first time I've been under my Jimny. While I was underneath I noticed this on the front passenger side:
Can someone tell me if this is grease or oil and whether it means a seal has gone?
Is there something I need to replace?
- jonesyba420
05 Apr 2014 15:11 #111325
by jonesyba420
Replied by jonesyba420 on topic Grease or oil? Help please!
Its diff oil leaking through the inner axle seal. Do you have death wobble? Chances are the king pin bearings and seal need changing. There is a guide on the home page.
05 Apr 2014 15:28 #111327
by Casey
Replied by Casey on topic Grease or oil? Help please!
Yes I do have wobble, that's why I was fitting the damper.
Is the inner axle seal part of the kingpin replacement? I've had a look already at the guide, but am a bit wary about starting it as it looks like a big job.
- dirtydogz
05 Apr 2014 15:49 - 05 Apr 2014 16:05 #111328
by dirtydogz
Replied by dirtydogz on topic Grease or oil? Help please!
I've replaced one set of king pins in about two hours and that was my first time, so just follow the guide and you will be ok.
www.bigjimny.com/index.php/forum/8-my-ji...t-top?start=84#61901
Good luck.
DIRTYDOGZ
Good luck.
DIRTYDOGZ
Last edit: 05 Apr 2014 16:05 by dirtydogz.
05 Apr 2014 16:08 #111331
by Casey
Thanks for your help guys. It's time to bite the bullet and get them changed I guess.
I assume that I'll need to change the diff oil at the same time.
- dirtydogz
05 Apr 2014 16:25 - 05 Apr 2014 16:25 #111334
by dirtydogz
No mate,
You only need to change it if its old oil, the oil will run back into the diff when you jack it up, so just top it up at the end.
Last edit: 05 Apr 2014 16:25 by dirtydogz.
