Problems installing keyless entry...
- jonesyba420
12 years 8 months ago #107669
by jonesyba420
Replied by jonesyba420 on topic Problems installing keyless entry...
Id try diagram 1 section C.
Im no expert tho.
Im no expert tho.
- blynkar
12 years 8 months ago #107694
by blynkar
Replied by blynkar on topic Problems installing keyless entry...
But should i tap lock and unlock wire into the one ive found?
Can take a picture of it.
- Jimnyash
12 years 8 months ago #107695
by Jimnyash
Replied by Jimnyash on topic Problems installing keyless entry...
When I installed mine, I found there was a couple of different wiring looms for the Jimny based on their age.
I didn't need to add any motors, just tapped into the wires in the loom to the side of the radio.
The main issue I has was getting the indicators to flash, which required a relay due to the negative switching.
12 years 8 months ago #107696
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Problems installing keyless entry...
If yours is an early jimny the door lock has one less wire than the layer m13a ones, ids a doodle on the m13 but the g13 on mine i have up! Separate solenoid would be the way,
Grey pick up Jimny
- blynkar
12 years 8 months ago #107716
by blynkar
Have an '98 registrered in '99.
12 years 8 months ago #107718
by j999pre
Grey pick up Jimny
Same as mine, different wiring and one less wire to the body control module
Grey pick up Jimny
Time to create page: 0.115 seconds
