Problems installing keyless entry...
- blynkar
12 years 8 months ago #107565
by blynkar
Problems installing keyless entry... was created by blynkar
Only have one key for my Jimny, and thought a keyless entry system would be some extra security.
www.alibaba.com/product-detail/User-manu...tion_1614860160.html
Bought a similar kit as the one in the link.
Have tried to follow the wiring instructions but it will only lock, not unlock.
Any guys here wanting to explain me how?
- 410shotgun
12 years 8 months ago #107593
by 410shotgun
Replied by 410shotgun on topic Problems installing keyless entry...
put a 2 wire lock motor in the drivers door
and this makes it easy I have done lots like this
- blynkar
12 years 8 months ago #107596
by blynkar
Replied by blynkar on topic Problems installing keyless entry...
Have ordered one, but I still want to find a solution for this...
Have tried several wiring combinstion, but all of them just locks. Not lock and unlock, just lock.....
There's a brown wire going to the drivers side door that get's 1,1V constant when locked. When I ground that wire to chassis it unlocks.
Thinking of some way to control this with a relay? Suggestions???
- jonesyba420
12 years 8 months ago #107605
by jonesyba420
Replied by jonesyba420 on topic Problems installing keyless entry...
Which diagram did u use to wire it?
Believe the jimny negative switched.
- L7kvv
12 years 8 months ago #107607
by L7kvv
Replied by L7kvv on topic Problems installing keyless entry...
I just wired mine up on its own circuit. Power wire to the battery and negative to ground. Connect the solinoid up to the bar that goes from door pin to the lock and bobs yer uncle
- blynkar
12 years 8 months ago - 12 years 8 months ago #107641
by blynkar
Have diagram tried 1 and 3. But them both just makes it lock, and then I manually have to unlock.
Think I'm spending some time out in Jim' tomorrow trying to see what I cam do.
Anybody have another wirimng diagram I can try with?
Last edit: 12 years 8 months ago by blynkar.
Time to create page: 0.103 seconds
