Vitara front brake upgrade
- DVF
16 years 3 weeks ago #5327
by DVF
Vitara front brake upgrade was created by DVF
I've heard that it's possible to fit Vitara front brakes and vented discs to the Jimny.
Anyone got details of this mod?
What parts are required?
Which model Vitara would I get the parts from?
Ta.
Ta.
16 years 3 weeks ago #5328
Replied by mlines on topic Re: Vitara front brake upgrade
If I recall correcty then all vitara front brake parts fit jimnys. The exception being the Vitara with the vented discs, but even these fit if you change everything at one.
I could be wrong, but this is how I remember it
- DVF
16 years 3 weeks ago #5329
by DVF
Replied by DVF on topic Re: Vitara front brake upgrade
It's the vented ones I'm after. I've already warped one pair of discs and well on the way to warping another pair. Need something that will stand up to my thinking the Jimny is a racecar.
Which Vitaras had vented discs?
16 years 3 weeks ago #5362
by kirkynut
Replied by kirkynut on topic Re: Vitara front brake upgrade
I'm not too sure I'd want too much more braking in the wet with mud terrains on - it's easy enough to lock up my fronts in the wet now, let alone with stronger brakes!!!
- darthloachie
16 years 3 weeks ago #5380
by darthloachie
don't forget DVF has a posh one with abs!
Replied by darthloachie on topic Re: Vitara front brake upgrade
kirkynut wrote: I'm not too sure I'd want too much more braking in the wet with mud terrains on - it's easy enough to lock up my fronts in the wet now, let alone with stronger brakes!!!
- Zapnologica
- Junior Member
6 years 4 months ago #223824
by Zapnologica
2015 Suzuki Jimny
4" 100mm Lift
M18A Motor
Crawler Gears
Dual Air Lockers
Lots of mods.
Replied by Zapnologica on topic Re: Vitara front brake upgrade
Any more details on this?
I have 29inch tyres and my breaks are really not great at all.
I would really like the vitara disc's and calipers as they are larger. Does anyone know which year and model will fit?
2015 Suzuki Jimny
4" 100mm Lift
M18A Motor
Crawler Gears
Dual Air Lockers
Lots of mods.
Time to create page: 0.113 seconds
