10mm square drain plug key
- steffan
26 Feb 2014 09:53 #106173
by steffan
Replied by steffan on topic 10mm square drain plug key
I find the 3/8 ratchet abit loose
26 Feb 2014 12:56 #106187
by Rhinoman
Replied by Rhinoman on topic 10mm square drain plug key
I also found found the 3/8 too loose, so I bought a 10mm adapter from the local motor factors - much easier than having to remove a damaged plug.
- Wiltec17
26 Feb 2014 13:42 #106198
by Wiltec17
Replied by Wiltec17 on topic 10mm square drain plug key
A set of drain plug keys can be had on eBay for about a tenner, if you need them urgently then they are available at halfrauds
- GuardianAngel
26 Feb 2014 13:53 #106203
by GuardianAngel
Mine has slightly rounded corners too make it easier to fit onto a socket, and I found it slipped out of the drain plug as a result, increasing the chances of rounding it off, so I got a proper drain plug socket which works much better.
Replied by GuardianAngel on topic 10mm square drain plug key
steffan wrote: I find the 3/8 ratchet abit loose
- MWells
26 Feb 2014 15:25 #106212
by MWells
Replied by MWells on topic 10mm square drain plug key
I got mine from
here
- jonesyba420
26 Feb 2014 16:18 #106219
by jonesyba420
Replied by jonesyba420 on topic 10mm square drain plug key
i just hold the 3/8 ratchet head firmly in place so it cant twist out.
the plugs shouldnt be overly tight anyway....................they dont need to be FT!
Time to create page: 0.103 seconds
