10mm square drain plug key
- Thank you received: 77
26 Feb 2014 07:12 #106146
by robs5230
standard jimny - for now
10mm square drain plug key was created by robs5230
anyone know who stocks a 10mm square drain plug key ? ( apart from the main stealers ).
just looking for a single tool not a set. it's for the diff filler plugs and i'd like to try a correct tool before i resort to other methods.
thanks
thanks
- steffan
26 Feb 2014 08:00 #106149
by steffan
Replied by steffan on topic 10mm square drain plug key
Get some solid bar and grind square until it fits nice and tight
- gilburton
26 Feb 2014 08:38 #106155
by gilburton
Replied by gilburton on topic 10mm square drain plug key
Most auto accessories stores sell them if they sell tools
You can get the bar type or the ratchet key type.
Wilco,Halfords,Autoworld or any half decent accessory shop in your area
www.wilcodirect.co.uk/catalogue/search/t...rain%20plug/type/all
I think Halfords only sell the set for £19.99 but I know these are available loose
26 Feb 2014 08:54 #106160
Replied by mlines on topic 10mm square drain plug key
The square end of a 3/8 socket set ratchet fits
26 Feb 2014 08:56 #106163
by safari
if u worry u die if u dont worry u still die so why worry
Replied by safari on topic 10mm square drain plug key
I just use the extention bar socket it fits well and bought for 50c (china product) to fit
- jonesyba420
26 Feb 2014 09:00 #106164
by jonesyba420
+1
works a treat
Replied by jonesyba420 on topic 10mm square drain plug key
mlines wrote: The square end of a 3/8 socket set ratchet fits
+1
works a treat
Time to create page: 0.113 seconds
