lost 4 wheel drive
03 Jan 2014 22:26 #98955
by kirkynut
Replied by kirkynut on topic lost 4 wheel drive
Nah, leaving them locked won't have caused it. Like I say, I think they just need a bit of tlc.
Just don't over grease them. They just need a little bit to stop binding. It's probably old grease gone hard in the cold stopping them sliding inside.
03 Jan 2014 22:37 #98957
by robs5230
standard jimny - for now
Replied by robs5230 on topic lost 4 wheel drive
if the hubs are at fault and they may be, a strip and clean/relube should sort it. i bought a set that needed rebuilding and its a quickish job . check as mentioned in other posts. once you have cured the faulty hub , i'd also redo the working one.
- idiotmobil
03 Jan 2014 22:47 - 03 Jan 2014 22:48 #98960
by idiotmobil
Replied by idiotmobil on topic lost 4 wheel drive
Just watched a video of a rebiuld looks easy ill be doing them over the weekend can I just undo the hubs anf pull them off with every thing else still there wheels etc
Last edit: 03 Jan 2014 22:48 by idiotmobil.
04 Jan 2014 08:24 #98985
by robs5230
to be honest i can't remember whether the wheel has to come off or not. but i do remember you can strip and rebuild them on the dining room table
i bought the grease and sealant from the bigjimny shop. martin will tell you what you need.
rob
rob
- vitara_mad
04 Jan 2014 11:19 #99010
by vitara_mad
Replied by vitara_mad on topic lost 4 wheel drive
no need to remove anything else to take the hubs off so very easy 5min job
- idiotmobil
04 Jan 2014 11:28 #99012
by idiotmobil
cool ill be doing them in a bit just in the middle of making the mould for the fast back hard top right now and its going quite well
Time to create page: 0.098 seconds
