lost 4 wheel drive
  • idiotmobil
03 Jan 2014 18:37 #98908 by idiotmobil
lost 4 wheel drive was created by idiotmobil
drove on to the beach tonight to see the stormy weather got a little stuck so selected 4 wheel drive and the light come on but still only had two wheel drive got out checked my hubs were locked on and they were (manual hubs) also unlocked the relocked just incase, managed to get unstuck some how and drove home ive had a look on the drive but only quick as its tipping it down unlocked hubs and selected 4 wheel drive and the front shaft doesn't turn but does when in two wheel drive so the transfer box seams to be working, I had a bit of a play on the stones spinning the wheels up and only the rear were spinning and not both the front does this sound like front diff as both side not working, there's no funny noises all would seam fine I would of never noticed if not needed 4x4
  • Mud_Muppet
03 Jan 2014 20:14 #98934 by Mud_Muppet
Replied by Mud_Muppet on topic lost 4 wheel drive
I could be wrong or I've read it wrong, but say if you've snapped a shaft/ broken a cv all the "power" would go through the broken side as it's an open diff ?
Hope that makes sense
  • idiotmobil
03 Jan 2014 20:24 #98935 by idiotmobil
Replied by idiotmobil on topic lost 4 wheel drive
sort of makes sense so if a cv half shaft or hub was broke the other wheel should spin I thought it would just act as if the wheel was in the air, say the hub spline was stripped it would spin and the other wheel wouldn't, im sure there would be some sort of noise I drove home with hubs locked and head out window and didn't hear a thing think ill just strip the lot and have a quick look regrease etc. wile im at it
  • vitara_mad
03 Jan 2014 20:26 #98938 by vitara_mad
Replied by vitara_mad on topic lost 4 wheel drive
I would start with taking the hubs off & make sure they are actualy locking
  • TomDK
03 Jan 2014 20:28 #98939 by TomDK
Replied by TomDK on topic lost 4 wheel drive
What happens if you put it in 4wd?
Can you rotate the front drive shaft with your hands?
  • idiotmobil
03 Jan 2014 20:34 #98942 by idiotmobil
no stick it in 4 wheel drive and the shaft doesn't turn 2 wheel drive it does transfer box seams fine and its a quite new rock lobster so glad that's ok
I was hoping it was just hubs but wouldn't it have to be both broke at same time its possible but surely unlikely
Time to create page: 0.186 seconds
