G16 swap problem
  • greenjimny
14 Dec 2013 16:28 #95975 by greenjimny
Replied by greenjimny on topic G16 swap problem
j999pre wrote: Hi, no I didn't get the email. I'm getting the baleno injectors Wednesday so will try it then. I'm sure there is a solution. Cheers
heres the pic that was in the email
14 Dec 2013 16:34 #95976 by j999pre
Replied by j999pre on topic G16 swap problem
Cheers for that, did it the same way but had one of the mountings that was cut off rewelded on to line up with the bottom hole under the left hand manifold stud, good and strong,!
Grey pick up Jimny
  • Dave n lincs
14 Dec 2013 18:02 #96025 by Dave n lincs
Replied by Dave n lincs on topic G16 swap problem
Iv done a conversion into mine and on first start up it ran like crap but then cleared after a short run. I put a baleno motor in mine and it came with the complete green injectors in without any metal showing. Did you use the jimny manifolds and all jimny sensors off your original motor? It is worth checking all vac pipes aswell for leaks. Did you change the timing belt or check timing before fitting? :)
14 Dec 2013 18:43 #96044 by j999pre
Hi,
Yes i used all the manifold from the jimny.
Changed the timing belt so i'll check that. I'm thinking air leak or injectors.
Grey pick up Jimny
  • Cider
14 Dec 2013 21:46 #96069 by Cider
Replied by Cider on topic G16 swap problem
j999pre wrote: Pete did you swap the cam sensor housing over for the jimny one? Just wondering if its a cam sensor issue.
I've got some green injectors coming so will try those too.
Maybe I missed something simple.
Hi james
Pretty sure I used the jimny cam sensor as I had trouble unplugging it when removing the g13 unit
20 Dec 2013 18:30 #96956 by j999pre
Update
Mis fire was damp on a coil.
With gv injectors it still had a bit of a flat spot before 3000 revs
Fitted baleno green injectors and its much better.
Happy days. Need to do it to my own now!
Grey pick up Jimny
Time to create page: 0.150 seconds
