G16 swap problem
12 years 11 months ago #95903
by j999pre
Grey pick up Jimny
G16 swap problem was created by j999pre
For those in the know.
I've just fitted a grand vitara g16b into a hard top 1998 jimny.
All went well, no sump to swap, cam was correct one. Usual adapter plate and a few mods to do.
My question is i've used the grand vit injectors. Are these ok to use with the standard jimny ECU? The car starts perfect,idles well but misfires under load? Any thoughts from those that have done this or know the ECU issues etc.
I've heard about using the green bakeno injectors but are they the same cc as the grand vit 1.6 ones.
Really happy with it bar the stutter/miss.
Cheers
Cheers
Grey pick up Jimny
- Cider
12 years 11 months ago - 12 years 11 months ago #95910
by Cider
Replied by Cider on topic G16 swap problem
Hi
My gv engine conversion runs fine with standard gv 1.6 injectors running off a standard 1.3 hard top jimny ecu
still got them in there
plus never had any problems when I fitted green baleno injectors
I`m sure the ecu can be re mapped "thinking about getting mine done" before its mot
Last edit: 12 years 11 months ago by Cider.
12 years 11 months ago #95917
by j999pre
Grey pick up Jimny
Replied by j999pre on topic G16 swap problem
Pete did you swap the cam sensor housing over for the jimny one? Just wondering if its a cam sensor issue.
I've got some green injectors coming so will try those too.
Maybe I missed something simple.
Grey pick up Jimny
- Dave cc
12 years 11 months ago #95918
by Dave cc
Replied by Dave cc on topic G16 swap problem
Did 1 a while back never again ok was a 8v 1600 block with a jimny head but tried to run it on standard injectors without luck misfired due to mixture being to lean so tried the big green baleno injectors without luck then the small green baleno ones was better but wasnt correct just seemed to be running lean all the the time.
If you unplug the air temp sensor does it run better ? i assumed at the time it was because unplugging it put the ECU into limp mode and somehow increased the fueling gave up and sold it on in the end
- greenjimny
12 years 11 months ago #95956
by greenjimny
Replied by greenjimny on topic G16 swap problem
i swapped the cam sensor housing just incase , im running the baleno injectors too and so far no problems .
did you get my email ?
cheers
cheers
12 years 11 months ago #95963
by j999pre
Grey pick up Jimny
Hi, no I didn't get the email. I'm getting the baleno injectors Wednesday so will try it then. I'm sure there is a solution. Cheers
Grey pick up Jimny
Time to create page: 0.099 seconds
