Replacing brake calipers
- 2013gary
12 years 11 months ago #95736
by 2013gary
Replacing brake calipers was created by 2013gary
Hi everyone,
Is replacing the brake calipers a job for the skilled mechanic, or is it something I can do myself? I've changed pads and discs a few times before so I have some experience with brakes.
I was able to source refurbished calipers cheaper than my mechanic could get new ones, so I'm not sure whether to have him come and fit them so that I can watch and learn, or just have a go myself? It's quite frustrating because it doesn't look like too difficult a job... but then I could well be underestimating it.
- 410shotgun
12 years 11 months ago #95740
by 410shotgun
Replied by 410shotgun on topic Replacing brake calipers
if you can change the pad and discs than you should be able to do the caliper
- Fyffe
12 years 11 months ago #96350
by Fyffe
Replied by Fyffe on topic Replacing brake calipers
Just make sure to bleed them all down properly before test driving and to not round the bleed nipple then you will be fine!
- jonesyba420
12 years 11 months ago #96380
by jonesyba420
Replied by jonesyba420 on topic Replacing brake calipers
if re-assembly is your concern (lets face it anyone can take something apart its putting it back together that gets ya) take pleanty of pictures of the process as you disassemble.
- gilburton
12 years 11 months ago - 12 years 11 months ago #96414
by gilburton
Replied by gilburton on topic Replacing brake calipers
Doesn't really apply to disc brakes but I always just dismantle one side then you always have the other for reference. Used to find that helps in drums so that you know where all the springs go lol
Spray the bleed nipples,bolts etc. with WD40 or similar a couple of days before.
Last edit: 12 years 11 months ago by gilburton.
- 2013gary
12 years 11 months ago #96421
by 2013gary
Replied by 2013gary on topic Replacing brake calipers
Thanks for your replies I will have a go myself at the weekend.
