Unplug and/or remove from air box
- Reloaded
24 Nov 2013 12:12 #92937
by Reloaded
Replied by Reloaded on topic Unplug and/or remove from air box
^^^ that's the way to do itfacade wrote: It won't fuel right with it disconnected, dangling it in the engine bay is better, drilling a hole in the new filter and fitting the sensor through a grommet is best.
- JamJim
24 Nov 2013 15:32 #92958
by JamJim
Replied by JamJim on topic Unplug and/or remove from air box
Air intake temp sensor. The Jim will run fine with it plugged, or unplugged into the air box. I am running a cone filter setup as well, I've just left it dangling. No issue.
- jonathan
25 Nov 2013 18:15 #93146
by jonathan
Replied by jonathan on topic Unplug and/or remove from air box
i will put an engine management fault in the system you need it there for the injection system to work propoly
- markyp2000
25 Nov 2013 18:45 #93153
by markyp2000
Replied by markyp2000 on topic Unplug and/or remove from air box
I left mine unpluged for weeks after fitting my snorckal kit wasnt till i look in the air box to see if rain water went down it i found it swinging in the wind and it drove the same and made not difference to fuel consumption
- piprice
25 Nov 2013 19:21 #93162
by piprice
Replied by piprice on topic Unplug and/or remove from air box
Removed mine and put it back, nearly forgot tho! Also after fitting snork!
Normally sensors are there for reasons- many infact!
But hey your jimny you do the hell you like
25 Nov 2013 19:27 #93166
Replied by helijohn on topic Unplug and/or remove from air box
Now I know I can simply replicate it's position with a bore hole in the filter body.
