Abs light stays on
- Dave cc
:laugh: :laugh: :laugh: :laugh:
- macguyverjimny
will do, but for the mean time ill drive it as it is till i have some free time.
macguyverjimny wrote: where the cable goes on top of the radius arm over the axle to the hub..... That part had like no slack in the wire, the wire was very stiff connected, so it seems that metal plate that connect the wire to the radius arm bent, so i think i would need to replace the sensor then at the rear hub,
I bent the metal plate on the radius arm back to its position so that there is more slack for the line over the axle to the hub.
You may have fractured the wire by stretching it.
The wire is part of the sensor, but you might be able to splice a piece of wire in and temporally repair it when you know for certain which sensor has failed.
I don't think a new sensor can be much more than about £200, as Cam Suzuki will sell you a second hand pair for £40.(If you get a dealer to fix it you will get the joke I made earlier, Dave did :lol: :lol: )
- Dave cc
- macguyverjimny
thanx alot
The one about washing it with soap ?
The dealers tend to tell me that my car arent allowed to drive through mud or water as it is a 4x4
- markyp2000
