d22 help
- 410shotgun
12 years 11 months ago #92677
by 410shotgun
Replied by 410shotgun on topic d22 help
it goes in gear the pedal is all ok
but no props turning in 2 or 4wd
just don't move or make any noise
I think the transfer box is chain drive
- gaz3359
12 years 11 months ago #92691
by gaz3359
Replied by gaz3359 on topic d22 help
Its difficult to say without been there to look and try it out so to speak,id agree with rich its probs the clutch,friction plate may have collapsed.think if it was the transfer box you may have get some bangs when trying to drive.i could be wrong but just going off what you have said.how does the 4wd work ? Have you engauged 4wd and tried pulling away.
- 410shotgun
12 years 11 months ago #92710
by 410shotgun
4wd is a stick put it in high or low just the same
it could be the clutch but no fault with it before hand
- Yellostreak
12 years 11 months ago #92712
by Yellostreak
Replied by Yellostreak on topic d22 help
this might help...
www.nissan-navara.net/viewtopic.php?f=3&t=32172
also night find some more info from them by doing some digging
- Dave cc
12 years 11 months ago #92713
by Dave cc
Replied by Dave cc on topic d22 help
I know the Ford rangers/Mazda pickup used to sheer the input shaft into the gearbox not sure if the nissan uses the same box
would have thought if the clutch had broken up would have given some warning and poss some noise when it went
- 410shotgun
12 years 11 months ago #92761
by 410shotgun
I could be the input shaft
but need to get the box out and see
I took the gear box fill plug out and turned the prop
and you could see the box is turning
so clutch or input shaft
Nissan 1st say the gear boxes are very good and no common faults
so big job on now in the cold
Time to create page: 0.095 seconds
