d22 help
- 410shotgun
22 Nov 2013 18:56 #92645
by 410shotgun
d22 help was created by 410shotgun
I know this is a jimny forum
but can anyone help with my Nissan d22
out today and lost drive
could it be clutch /gearbox or transfer box ????
anyone help out
anyone help out
- Yellostreak
22 Nov 2013 20:01 #92656
by Yellostreak
Replied by Yellostreak on topic d22 help
if it went suddenly then gearbox/transferbox, if it went gradually then its the clutch.. last D22's are essentially a D40 transmission and my D40 had 2 flywheels and 3 clutch plates by the timeit was 30k miles old..
fine now it has a solid lump of single mass flywheel..
- 410shotgun
22 Nov 2013 20:21 #92661
by 410shotgun
Replied by 410shotgun on topic d22 help
just driving along and than no drive no bang or clonk
do know a lot about them
is the transfer box a chain drive ??
- gaz3359
22 Nov 2013 20:33 #92663
by gaz3359
Replied by gaz3359 on topic d22 help
Dont know alot about these but,can you get it into gear with the engine running ? does it feel like there is a pedal/biting point ?? any sort of noises other than clunks bangs ?? could be a clutch master cylinder ?? just a thought
- Thank you received: 2006
22 Nov 2013 21:43 #92674
Not teaching you to suck eggs but it is in gear on the transfer box not just slipped into neutral. My old disco used to be a git for that.
- RichiesJimny
22 Nov 2013 21:45 #92675
by RichiesJimny
Replied by RichiesJimny on topic d22 help
My guess would be clutch, start it up put it in gear and get somebody to look under it to see if any of the props are turning (keep your handbrake on and keep your foot on the brake)
