G13bb engine head damaged.
  • Cider
15 Sep 2013 21:02 - 15 Sep 2013 21:03 #83315 by Cider
Replied by Cider on topic G13bb engine head damaged.
Hi
As long as the 1.6 has the ht coil packs "ie baleno or grand vitara it`ll fit your jimny you will
have to make sure the cam sensor ring the same or you`ll have to swop the whole cam over
You do not need the 1.6 injectors
Last edit: 15 Sep 2013 21:03 by Cider. Reason: o
15 Sep 2013 21:29 #83325 by Rhinoman
Replied by Rhinoman on topic G13bb engine head damaged.
I don't know about the head but the 1.6 block is taller.
  • Dave cc
16 Sep 2013 13:52 #83362 by Dave cc
Replied by Dave cc on topic G13bb engine head damaged.
From the way i understand it you can fit the 1600 head the valves according to what i have researched are 1mm bigger so no big deal there
The height of the head is the same and i would stick with the 1300 injectors must admit i have never put a 1600 head on a 1300 block done it the other way by putting the 1300 head on a 1600 block and that worked fine
  • Reckerr
17 Sep 2013 10:45 - 17 Sep 2013 10:54 #83450 by Reckerr
Replied by Reckerr on topic G13bb engine head damaged.
In terms of specs. Fitting the 1300(is this g13bb from the jimny or g13b gti head?) what are the benefits.
Again in terms of specs. What would happen the other way around. So all these question theoretically based on figures. If an answer is possible. If not . Thanks a million for the help on the heads.
Mechanic said I was lucky because usually when the oil stops circulating, the parts in block are the first to go and knock the engine. But the parts in my head by the camshaft dried of oil first. SO I guess I'm lucky.
Last edit: 17 Sep 2013 10:54 by Reckerr.
Time to create page: 0.104 seconds
