G13bb engine head damaged.
  • Reckerr
14 Sep 2013 22:17 #83182 by Reckerr
G13bb engine head damaged. was created by Reckerr
Oil wasn't reaching the head and the head is damaged. Investigating if it's a dead pump or clogged sump. I got offered a g16b head. Will that bolt straight onto the g13bb block and will any mods need to be done to get everything in order?
Are there any benefits in the 16 head on the 13 block? Are there any increases in power?
  • Reckerr
15 Sep 2013 14:00 #83237 by Reckerr
Replied by Reckerr on topic G13bb engine head damaged.
Any ideas? Want to be sure everything is ok before i buy it.
  • russell
15 Sep 2013 14:13 #83238 by russell
Replied by russell on topic G13bb engine head damaged.
I think iv got a g13b bare head just a bare head no valves just the alloy head for sale if needed email me waynerussell8888@hotmail.com
  • Reckerr
15 Sep 2013 14:47 #83252 by Reckerr
Thanks for the help. But I'm not in the UK and getting that would be much more expensive than one from here.
I would be able to get one 1300 from a baleno but the 1600 is cheaper. So jus inquiring if it's a match.
And I need the whole head. The lack of oil on the shaft caused some metal-metal rubbing/scratching/digging. But didn't knock...
  • russell
15 Sep 2013 17:21 #83277 by russell
Personally from what iv seen the heads and blocks are the same it's the stroke that is different and maybe the bore size but I think it's just a longer stroke on the 1.6 and I know for sure the injectors would be different I can't see why the valves and cam would vary but the injectors would defernatly be diffrent but as far as I know the head will bolt straight on
  • Reckerr
15 Sep 2013 17:24 #83278 by Reckerr
So just confirming. I'm still fairly new to the engine and mechanics and such. I will definitely need the injectors for the 1.6 if I put this 1.6 head on my g13bb jimny.
Time to create page: 0.228 seconds
