Cat astrophe
gus2000 wrote: Turning on the air conditioning, the CO at idle drops markedly :lol:
Gustavo
Interesting but not allowed over here. Have you got any numbers from the emissions test?
Please bear in mind that the contents of the cat may be expensive and an original cat may have a high scrap value.
Gustavo
So the tester will turn off the Aircon then???
I started this thread because I am thinking I'd like to fit a stainless steel system with no cat in it.
- RichiesJimny
- markyp2000
RichiesJimny wrote:
markyp2000 wrote: Thats for a cat test you need to find a cope of the seventeenth adition emmisions data book
Suzukis are tested like a car with out a cat
You want to hope there's no VOSA area inspectors on this forum
And whys this how are thay going to know who i am and where i do mot test
I will tripple check tomorrow with vosa again to 100% comferm this
- markyp2000
helijohn wrote:
Gustavo
Mot tester shouldnt turn any thing on or off apart from the lights and testable items as if it brakes then we will be in big dodo
helijohn wrote: So the tester will turn off the Aircon then???
To quote the MOT manual:
The engine should be idling normally during the test and should not be subject to significant electrical loading such as heated seats or heated rear windows.
I would certainly expect the air-con to be turned off as that constitutes a high load at idle. I'm certain that you won't get away without having something that at least resembles a cat.
