Cat astrophe
01 Jul 2013 18:01 #75685
Cat astrophe was created by helijohn
So what's the crack on removing the cat exhaust system and throwing on a non cat system.
- RichiesJimny
01 Jul 2013 18:58 - 01 Jul 2013 20:31 #75699
by RichiesJimny
It needs the cat for the mot unless you know a dodgy testing station.
Replied by RichiesJimny on topic Cat astrophe
helijohn wrote: So what's the crack on removing the cat exhaust system and throwing on a non cat system.
Last edit: 01 Jul 2013 20:31 by RichiesJimny.
01 Jul 2013 19:48 #75708
Can't it be got round???
Replied by helijohn on topic Cat astrophe
It needs the cat for the mot unless you know a dodgy testing satiation.
01 Jul 2013 19:58 #75710
by Rhinoman
Replied by Rhinoman on topic Cat astrophe
If its in good nick it could pass the emissions test without a cat but the new regulations state that if it had a cat from new then it must have one.
- markyp2000
01 Jul 2013 20:43 #75723
by markyp2000
Replied by markyp2000 on topic Cat astrophe
No suzuki/jimny should fail an emmisions test as thay are not in the seventeenth addition exhaust date book for the mot testing station thay all have one so if you was to take the cat off and cut the top off then remove the cat then weld the top back on it will pass the mot if the station know what thay are doing
02 Jul 2013 21:14 #75829
by Rhinoman
Is that the same for the Vitara? what exactly is the test? I think I read somewhere that it is done at 2500RPM with no load on the engine.
