Stripped the captive nut in my front panhard rod
- ne-crock
27 Jun 2013 06:59 #75235
by ne-crock
Stripped the captive nut in my front panhard rod was created by ne-crock
As the title says i've stripped the nut in my front panhard rod mount which is under the spring seat which makes it difficult to get to,
The car is currently undrivable as i've found out on my drive to work this morning, anything over 20mph and the car is trying to kill itself whilst its shaking,
Anyone got any clever ideas how i can fix this?
My tool kit is limited and thats being kind to it,
I thought a longer bolt but that went out the window when i realised it will foul the axle casing
- UKDAN
27 Jun 2013 08:16 #75238
by UKDAN
Replied by UKDAN on topic Re:Stripped the captive nut in my front panhard rod
Get your self a tap & die set & recut the thread ?
Dan
Dan
- markyp2000
27 Jun 2013 09:45 #75245
by markyp2000
Replied by markyp2000 on topic Re:Stripped the captive nut in my front panhard rod
Stripped the tread out of it or has it broken away so its spinning
- ne-crock
27 Jun 2013 09:53 #75246
by ne-crock
Replied by ne-crock on topic Re:Stripped the captive nut in my front panhard rod
I believe its stripped the thead,
As the bolts tightening its slipping and becoming loose giving the same effect as stripped threads,
I've just pit a new bolt in seein in the deeper thread has more to try bite, but the bolts a bit to long so i need a shorter bolt,
See how that gets on as long as i can get to the garage to get the new tyres
- GWR
27 Jun 2013 10:06 #75247
by GWR
You could cut the bolt to the length you need or put a couple/few washers on before putting the bolt in place so it doesn't protrude out the other side.
Replied by GWR on topic Re:Stripped the captive nut in my front panhard rod
j'sne-crock wrote: I believe its stripped the thead,
- markyp2000
27 Jun 2013 11:40 #75249
by markyp2000
Drill it out and try and get a nut and bolt through it
Dont put a different tread size in it as it my lock up and snap even worse snap the captive nut off the back then you wont get it out
Time to create page: 0.217 seconds
