Severe vibration 1800 to 2200 rpm
  • topjimny
29 Jun 2013 15:03 #75490 by topjimny
Replied by topjimny on topic Re:Severe vibration 1800 to 2200 rpm
My Jimny does that too. Only in 3rd, 4th and 5th gear, between 1500 and 2000 rpm (1700 is the worst). I can hear the rear windows rattling...
29 Jun 2013 20:32 - 29 Jun 2013 20:33 #75516 by facade
They all do that Sir ;)
New trailing arm bushes at the back and a rear UJ made mine reduce from self destruct mode to just very annoying.
The diesel has one of those harmonic damper thingies on the nose of the rear differential, most likely to reduce this, I suspect it is a resonance problem with the propshaft/axle, made worse by worn bushes or universal joints.
You could try bolting a lump of lead (depleted uranium would be better) to the bolt holes under the rear diff nose, this ought to move the vibration to a lower speed.
Last edit: 29 Jun 2013 20:33 by facade.
The following user(s) said Thank You: topjimny
  • topjimny
01 Jul 2013 16:52 #75678 by topjimny
Replied by topjimny on topic Severe vibration 1800 to 2200 rpm
Thanks for the info facade.
  • colinjgraham
03 Jul 2013 12:41 #75890 by colinjgraham
Replied by colinjgraham on topic Severe vibration 1800 to 2200 rpm
Sorry for not replying to posts, I have been away. When you say they all do that mine did not have any vibration at all until I had the gearbox rebuilt and a new clutch fitted, now it is virtually un-driveable at 30-40 ,mph in 3rd, 4th or 5th.
I know the exhaust is a flexi type with springs on the bolts and fire rings so the joints can flex, I messed about with it and the vibration reduced for a while but came back after I had driven a few miles. It may be resonating when it is flexed by the engine moving under load, not sure though :S Will investigate further an keep you posted, cheers
  • colinjgraham
16 Jul 2013 07:42 #77174 by colinjgraham
Hi, been away for a while, no further joy with reducing the vibrations, anyone know where I could get one of the weights that was mentioned by façade, from a diesel to bolt onto the dif? Cheers
16 Jul 2013 17:07 #77227 by Busta
Just drive it at 4,000rpm like your supposed to. Problem solved! ;)
Time to create page: 3.142 seconds
