Severe vibration 1800 to 2200 rpm
- colinjgraham
24 Jun 2013 20:02 - 24 Jun 2013 20:03 #74959
by colinjgraham
Severe vibration 1800 to 2200 rpm was created by colinjgraham
Hi, this is my first post so forgive me if I am going over old ground. I have just had the gearbox rebuilt and a new clutch fitted to my 56 reg jimny. It has now developed a severe vibration from 1800 to 2200 rpm. I cannot find the problem but suspect that the prop shaft is causing this even though it disapeares if you just touch the throttle. Cruising at 30 to 40mph is impossible due to the vibration. Any help would be great as I am a newbie on jimny, cheers.
Last edit: 24 Jun 2013 20:03 by colinjgraham.
- markyp2000
24 Jun 2013 20:41 #74966
by markyp2000
Replied by markyp2000 on topic Severe vibration 1800 to 2200 rpm
Vibration through what the steering or the chassis
One thing is it in 2wd
- colinjgraham
26 Jun 2013 12:07 #75146
by colinjgraham
Replied by colinjgraham on topic Severe vibration 1800 to 2200 rpm
Hi, thanks for the reply, the vibrations are through the chassis, I have only tried it in 2wd but will get on some slippy stuff and try 4wd as well. It seems worse in 3rd 4th and 5th though,
Cheers
Cheers
- markyp2000
26 Jun 2013 17:10 #75173
by markyp2000
Could be one of the front locking hub stuck on i had that on mine take them off and go for a drive and see if its ok
- colinjgraham
27 Jun 2013 09:12 #75244
by colinjgraham
Thanks for that, probably wont get a chance till the weekend now, I will post how it goes.
27 Jun 2013 14:07 #75254
Replied by mlines on topic Re:Severe vibration 1800 to 2200 rpm
I would have suspected a universal joint
Sent from my HP Slate 7 using Tapatalk HD
Time to create page: 0.176 seconds
