Severe vibration 1800 to 2200 rpm
  • markyp2000
16 Jul 2013 17:21 #77234 by markyp2000
Replied by markyp2000 on topic Severe vibration 1800 to 2200 rpm
Who says you have to drive it at 4000rpm
  • steffan
16 Jul 2013 17:41 #77247 by steffan
Replied by steffan on topic Severe vibration 1800 to 2200 rpm
Busta wrote: Just drive it at 4,000rpm like your supposed to. Problem solved! ;)
Don't talk poop your verbal diarrhoea offends my ears. :sick:
  • markyp2000
16 Jul 2013 17:49 #77253 by markyp2000
:cheer: dare i say it +1 lol :P
16 Jul 2013 21:05 #77277 by facade
They do "All do it Sir" to an extent, but as yours did not vibrate before then something has changed.
Could be the transfer box or gearbox mounts are tighter/ slacker
The engine could be lined up differently
Transfer box could be further forwards/backwards or lined up differently, changing the angle of the rear propshaft
Damper springs in the clutch plate could be different/loose this is the most likely reason I suspect. (What clutch was fitted?)
The differential damper is fitted to the diesel variant, which was never officially sold in this country, so at new Suzuki prices would be around £300 at a guess. You can try wandering round a scrapyard to find something that you can bolt to the holes on the diff nose, but I've no idea which cars fit a suitable one.
The following user(s) said Thank You: colinjgraham
  • markyp2000
16 Jul 2013 23:46 #77317 by markyp2000
Bmw 5 series exhausts have a anti vibrasion on the back box that bolts on
17 Jul 2013 09:43 #77331 by kevant
Try taking the prop off the rear stick it in 4wd hi and try it on the front wheels only then if it still does it do the reverse i did the same on mine and found out rear prop knacked ran round for a week with front wheel drive jimny
