GV 1.6 Engine swop
  • Cider
13 years 7 months ago - 13 years 6 months ago #67431 by Cider
GV 1.6 Engine swop was created by Cider
Hi All
As there`s very little info on the 1.6 Grand Vitara engine swop hopefully this will point anyone in the right direction
First start with one of these
one thing you`ll not have to do is to mess about with the oil pick up as the oil sump is the correct shape
same as the one on the jimny :)
The GV engine came with a crank sensor as standard but as I`m running a hard top I didn`t need it "Snip" :cheer:
The Gv engine came with the correct 11 point cam pick up for the hard top so no cam swop needed :laugh:
just below the cam pick up you`ll need to swop the heater pipe input/output replace with the blanking plate on your jimnys head
What I was going to do was to use the GV inlet manifold but as you can see its a lot taller then the jimnys
plus the gv engine is around 3cm taller to "might have problems fitting it in unless you`ve got a body lift"
And the idle control is different :unsure: I did mount a jimny one to it tho
Bits that need to be swopped over form your jimny engine
Alternator bracket
Power steering pump bracket
power steering belt adjuster "you`ll need to extend this as the mounting point are out"
[IMG
Water outlet behind the pump as the GV use 32mm hoses and the jimny 30mm "new mounting bracket needs to be made"
[IMG
Driver side engine mount will need to be either modified or remade as with the inlet manifold surport bracket got mine ready made from Rik email:waterbabies4x4@hotmail.co.uk number is 07587940297
[IMG
Passenger mount is ok
Replace the GV flywheel with the Jimnys and the clutch
Used both inlet and exhaust manifolds from the jimny
I used a SJ to vitara 1.6 engine conversion plate " abit of cutting to fit the clutch cable"
I Got my conversion plate from Rik email:waterbabies4x4@hotmail.co.uk number is 07587940297 Very Helpful
and a great service
Found a SJ Skinny starter also can be found on 8v vits Bosch 001-112-032
[IMG
I managed to get hold of a set of Baleno green injectors
longer fuel in and return pipes
longer power steering belt "I used 4PK868"
Finished and in the car
There`s plenty of info on the
baleno engine swop which is a great help. There`s a very good link to a Spanish site form the member gus2000
Well worth a read if your going to tackle an1.6 engine conversion
Good luck
Cheers
Pete
Last edit: 13 years 6 months ago by Cider. Reason: new pictures
  • markyp2000
13 years 7 months ago #67433 by markyp2000
Replied by markyp2000 on topic GV 1.6 Engine swop
Does it go and quicker and any more advantages
  • Cider
13 years 7 months ago #67441 by Cider
Replied by Cider on topic GV 1.6 Engine swop
markyp2000 wrote: Does it go and quicker and any more advantages
Don`t think it`ll make it faster,seems to cruise up to speed a lot better/Quicker
Not had the chance to off road it yet so the jurys out at the mo
  • Cider
13 years 7 months ago #67446 by Cider
Today I thought it`s worth a go in fitting the GV injectors even tho I`d fitted green baleno ones
Seems to fit ok on the jimny fuel rail and into the jimny inlet manifold without any modifciations :)
Turned the key and we have power with no leaks :cheer: :cheer:
Going to leave them in for a bit to see how it runs
GV 1.6 injectors are Bosch INP 770 77000XG "numbers taken from the body of the injector"
Cheers
Pete
  • gus2000
13 years 7 months ago #67476 by gus2000
Replied by gus2000 on topic GV 1.6 Engine swop
Congratulations :) :) :) :) :)
Very good job.........
you to enjoy the 1.6 engine
gustavo
13 years 7 months ago #67479 by j999pre
Replied by j999pre on topic GV 1.6 Engine swop
What year gv engine did you use?
Grey pick up Jimny
Time to create page: 0.128 seconds
