GV 1.6 Engine swop
- markyp2000
What year gv was it out of and whats the engine code g16?
- gus2000
Cider wrote: Hi
Well took the jimny off road last sunday and you can tell the difference
All went spot on until
Cheers
Oh more pictures added to the engine conversion write up
Hi Cider
The lower supports of the shock absorbers are extremely weak (front and rear)
Time ago I had to weld the rear left and reinforcing both front
Gustavo
- russell
- Cider
maybe an issue, So I had to use the jimny manifold. What I found on this site it was proven that the engine would run fine on baleno 1.6 injectors in the jimny manifold.
When the conversion was finished and the engine running well with the baleno injectors I tried the GV injectors as There was no info that they would fit on/in the jimny manifold. Plus as the baleno injectors are harder to find now
it might help someone if they knew their conversion would run on gv injectors
- russell
- Dave cc
russell wrote: Hope this is a sensible question are the 1.3 singel cam coil packs the same a s the gv 1.6 singel cam as my engine iv got didn't come with coil packs attached just wondered if my original ones would run properly I gess they would fit but do the run right personally I can't see why not as I'm running the original wireing loom
Just a coil that makes a spark mate shouldnt make a diffrence spark goes crack engine goes bang wheels on the bus go round and round
