Help bleeding brakes
- beretta
25 Mar 2013 11:01 #66862
by beretta
Help bleeding brakes was created by beretta
Hi, cam anyone give me a idiots guide to bleeding the brakes especially location of the nipples.
Will i have to bleed all the brakes, all that i am going to do is refurb the fromt left caliper, so i will only be touching that one.
Any particular tis to make it easy?
Cheers
Cheers
- GuardianAngel
25 Mar 2013 11:14 - 25 Mar 2013 11:16 #66863
by GuardianAngel
Replied by GuardianAngel on topic Re: Help bleeding brakes
Start with bleeding the rear, then passenger side the drivers side nipples.
Then to be 100% sure, the same order again but this time the feeds into the master cylinder.
Make sure the MC never runs dry of fluid.
Essentially you always bleed from the farthest points from the MC and work inwards to the nearest.
Last edit: 25 Mar 2013 11:16 by GuardianAngel.
- beretta
25 Mar 2013 11:22 #66865
by beretta
Replied by beretta on topic Re: Help bleeding brakes
Cheers, do you have a rough location on the nipples?
- GuardianAngel
25 Mar 2013 11:38 #66869
by GuardianAngel
The passenger side rear has a nipple that is exposed behind the back plate off the rear cylinder. The front calipers both have nipples.
Be careful, they are very easy to strip and snapoff if rusted or seized so be careful then trying to undo them!
Replied by GuardianAngel on topic Re: Re: Help bleeding brakes
beretta wrote: Cheers, do you have a rough location on the nipples?
- supergaz
25 Mar 2013 15:48 #66895
by supergaz
Replied by supergaz on topic Re: Re: Help bleeding brakes
Use a brake nipple spanner, a normal spanner will round off the nut.
- GuardianAngel
25 Mar 2013 16:03 #66898
by GuardianAngel
Good point but the rear nipples are 8mm and I struggled to find any brake spanners this size so had to use a ring spanner which seemed fine.
But for the fronts the nipples are bigger. They are either 10 or 11mm, cant remember. Halfrauds do these sizes.
Replied by GuardianAngel on topic Re: Re: Re: Help bleeding brakes
supergaz wrote: Use a brake nipple spanner, a normal spanner will round off the nut.
