Steering Wheels
  • adamatdraycott
22 Mar 2013 21:34 #66594 by adamatdraycott
Replied by adamatdraycott on topic Steering Wheels
The air bag module in the Mode steering wheel has a different plug/socket to the older grey wheel.
The newer wheels are only 3 spoke and different again inside
  • VAXXi
22 Mar 2013 21:49 #66595 by VAXXi
Replied by VAXXi on topic Steering Wheels
Licksan wrote: Maybe Sikaflex or Thixofix will work. I know Thixofix does a great job of sticking rubber to wood.
Just an idea: www.bison.net/en/products/642-contact-ad...duct/2207-bison-tix/
SUPER STRONG, UNIVERSAL CONTACT ADHESIVE GEL: EASY TO SPREAD, NO DRIPPING, NO STRINGING.
Bonds plastic panel boards (such as Formica®), veneer, hardboard, plastic edgings, rubber, leather, linoleum, cork, textile or polyether foam to themselves as well as to wood, chipboard, concrete and metal.
  • GuardianAngel
22 Mar 2013 22:11 - 22 Mar 2013 22:12 #66598 by GuardianAngel
Replied by GuardianAngel on topic Steering Wheels
Licksan wrote: I know Thixofix does a great job of sticking rubber to wood
Last edit: 22 Mar 2013 22:12 by GuardianAngel.
  • Licksan
22 Mar 2013 23:23 #66604 by Licksan
Replied by Licksan on topic Steering Wheels
Adam, any idea if a newer wheel will physically fit? Can air bag connectors be swapped?
Vaxxi sounds like that stuff is ideal. Worth a try if I go that route.
:laugh: @ GuardianAngel!! :P
  • Paul4x4
23 Mar 2013 09:26 - 23 Mar 2013 09:29 #66617 by Paul4x4
Replied by Paul4x4 on topic Steering Wheels
Licksan wrote: Adam, any idea if a newer wheel will physically fit? Can air bag connectors be swapped?
If I remember correctly, someone on here did swap his old steering wheel for the newer one. I think it was a bolt on job, and he managed to connect the wires too(maybe he cut the connector off and soldered the old one on it?).
Last edit: 23 Mar 2013 09:29 by Paul4x4.
  • little jimny
23 Mar 2013 22:28 #66717 by little jimny
Replied by little jimny on topic Steering Wheels
You can get the leather wheel from a Mode and just use your original airbag (the connectors on the Mode airbag are different) - that's what I did.
Failing that, I still have the original wheel, so if you're desperate for an original wheel that hasn't started to fall apart drop me a PM
Time to create page: 0.141 seconds
