Steering Wheels
  • Licksan
22 Mar 2013 18:50 - 22 Mar 2013 19:05 #66577 by Licksan
Steering Wheels was created by Licksan
The rubber on my 2001 4 spoke wheel has started to come away from the metal inside so the outer can be twisted in the 12:00 to 3:00 area. The car was owned originally by a guy on a mobility scheme so I think it may have had a handle or knob fitted which has caused this. I'm guessing its not fixable unless I can inject glue in some how!?
Did Suzuki offer any leather steering wheel upgrade or do any later models have leather wheels that would fit?
Last edit: 22 Mar 2013 19:05 by Licksan.
  • GuardianAngel
22 Mar 2013 18:57 #66579 by GuardianAngel
Replied by GuardianAngel on topic Re: Steering Wheels
I have the same problem and mine was a mobility car before I bought it.
  • Tadpole
22 Mar 2013 20:24 #66583 by Tadpole
Replied by Tadpole on topic Steering Wheels
If you feel like sitting for a couple of hours & at the end have the satisfaction of saying ‘I’m pleased with that’.
Purchase a ‘Leather Wheel Glove’ take your time & imo a worth while ‘mod’.
If it ever stops raining I’ll show you mine, cost all of £1.88 item #350633617146 ...... :whistle:
  • gus2000
22 Mar 2013 20:32 #66586 by gus2000
Replied by gus2000 on topic Steering Wheels
My steering wheel feels the same. (in the 11:00 to 2:00 área) :(
I think it is by excessive exposure to the sun, because the failure occurs on the upper side of steering wheel
I inject with a syringe 1.5 cc3 adhesive gasket distributed at various points of the affected area.
:S Does not work :S :unsure: No adhesive solvent evaporates, and not polymerize :unsure: and adhesion failure :dry:
:) Should be tested with a two-component adhesive to react together inside the steering wheel. :)
success
Gustavo
  • leswilluk
22 Mar 2013 20:50 #66588 by leswilluk
Replied by leswilluk on topic Steering Wheels
My 2009 Jimny has a leather steering wheel and leather trims to the interior it came with the posh option along with air con and aluminium wheels
  • Licksan
22 Mar 2013 21:02 #66591 by Licksan
Replied by Licksan on topic Steering Wheels
So the options so far are slice the rubber open, squeeze in some kind of adhesive to rebond the rubber and then cover the surgery with Leather like Tadpole suggests. (Does look like a satisfying project and soo cheap!)
Maybe Sikaflex or Thixofix will work. I know Thixofix does a great job of sticking rubber to wood. Will have to see if it works on metal and Sikaflex well that sticks to everything!
Or fit a replacement wheel that's newer or in better condition keeping my airbag.
Not seen in a newer Jimny but no doubt it has a different wheel. If I got one with airbag would it fit/work? Are they nicer?
Time to create page: 0.113 seconds
