Headlight assembly removal
- jonesyba420
20 Mar 2013 12:36 #66370
by jonesyba420
Headlight assembly removal was created by jonesyba420
im trying to find out how to remove the passenger headlight from my 02 jimny, ive searched on here with no results:(
ive tried undoing the 2 visible bolts but still couldnt get the light out!
any help greatly appreciated
20 Mar 2013 12:40 #66371
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Headlight assembly removal
There are two push in lugs into the frame behind the headlight. These are very tight. Either pull it our pry it carefully
Grey pick up Jimny
- jonesyba420
20 Mar 2013 12:43 #66374
by jonesyba420
Replied by jonesyba420 on topic Headlight assembly removal
I gave it a good pulling on felt like i was going to break something!! so theres definately nothing else holding it in other than the 2 bolts and the 2 little lugs?
cheers for your help.
- markyp2000
20 Mar 2013 12:57 #66379
by markyp2000
Replied by markyp2000 on topic Headlight assembly removal
Yank the fu*k ou of it or use a long screw driver to prize it off
- med
20 Mar 2013 13:09 #66380
by med
Replied by med on topic Headlight assembly removal
They can be very tight, spray wd40 on the two lugs and give them a rub with a wire brush, they will come off in the end, can use a large screwdriver or pry bar to give them a helping hand.
I thought exactly the same that i was going to break somthing but got there in the end!
- jonesyba420
20 Mar 2013 13:52 #66383
by jonesyba420
managed to get the lugs to come out (bit of WD40 and a small hit with a hammer) but the headlight still wont come fully out, seems to be stuck on the front bumper! think ive gained enough access tho to fit the pin switch for my alarm system.
do you have to remove the bumper for complete removal of the light or am i just being to much of a pussy?! i have a habbit of breaking things like this so i try not to be too heavy handed lol.
Time to create page: 0.166 seconds
