transfer bearing kit
  • Jimny - aus
17 Mar 2013 22:00 #66132 by Jimny - aus
transfer bearing kit was created by Jimny - aus
have diagnosed my transfer problem to be the input bearing....... now to source a bearing kit.. does anyone know if there is an aftermarket kit available or shall i proceed getting F#$cked and get a genuine kit... :pinch:
17 Mar 2013 22:51 #66142 by facade
Replied by facade on topic transfer bearing kit
Depends on how much time you have.
I've never seen the electric transfer, but on the lever type, the input shaft runs in two ball races, you split the casing, remove circlips and they come out, I doubt if much has changed.
Once they are out any good bearing supplier should be able to match them for you or you can read the bearing numbers and just order them.
  • gus2000
18 Mar 2013 00:22 #66147 by gus2000
Replied by gus2000 on topic transfer bearing kit
Hello, in the lever type transfer case, the three oil seal are identicals. (29972-80050)
if you do not use original parts, with the helical ribbed seals be careful with the direction of rotation of the oil seals.
Front and rear shafts rotating in different direction, relative to the oil seal
Expel the oil out if wrong rotating
Gustavo
  • Jimny - aus
18 Mar 2013 08:43 #66158 by Jimny - aus
Replied by Jimny - aus on topic transfer bearing kit
Thanks guys will give the bearing guy a call. Was hoping jimnybits would have a rebuild kit but there only for samari transfer. Not sure if they will help me out....
Time to create page: 0.083 seconds
