wheel play
  • freak
12 Mar 2013 13:25 - 12 Mar 2013 13:28 #65407 by freak
wheel play was created by freak
Hi everyone,
I got the car all jacked up the other day and noticed a little play in one o the front wheels. Is this a sign of bad wheel bearings or i just have to tight something there?
I don't know if it is a coincidence, but is just the one wheel that i pulled out the other day to try another. This other one is wider (7 inches), what caused a little lean in the front of the truck due to the 5.5 inches wide wheel on the other side of the SAME axle. I had the car like this for about 10 miles only before i switch back the original alloy into place. Are this 10 miles enough to damage the wheel bearing?
Thanks a lot!
Last edit: 12 Mar 2013 13:28 by freak.
12 Mar 2013 14:43 #65423 by j999pre
Replied by j999pre on topic wheel play
Wheel bearing or king pins
Grey pick up Jimny
  • freak
12 Mar 2013 17:18 #65434 by freak
Replied by freak on topic wheel play
Is there a way to tell which one?
  • vitara_mad
12 Mar 2013 18:25 #65458 by vitara_mad
Replied by vitara_mad on topic wheel play
yes there is a way to check if its kingpins or wheel bearings jack wheel off ground grab wheel at 9 & 3 oclock & shake wheel if theres play that way it will be wheel bearing if not then try 12 & 6 if there is just play that way it will be kingpin bearings
  • markyp2000
12 Mar 2013 18:30 #65460 by markyp2000
Replied by markyp2000 on topic wheel play
vitara_mad wrote: yes there is a way to check if its kingpins or wheel bearings jack wheel off ground grab wheel at 9 & 3 oclock & shake wheel if theres play that way it will be wheel bearing if not then try 12 & 6 if there is just play that way it will be kingpin bearings
9&3 oclock could also be a trackrod end if there is play in them
  • GuardianAngel
12 Mar 2013 18:33 #65462 by GuardianAngel
Replied by GuardianAngel on topic Re: wheel play
And if both ways does that mean both are knackered?
Time to create page: 0.256 seconds
