window washers not working
- Skinhead
25 Feb 2013 13:26 #63916
by Skinhead
window washers not working was created by Skinhead
As above, any ideas what it could be? Yes theres water in there :laugh:
- Jimñy aaron
25 Feb 2013 13:33 #63918
by Jimñy aaron
Replied by Jimñy aaron on topic window washers not working
Fuse or pump have you tried to use them while frozen??
- JivingDaddy
25 Feb 2013 13:36 #63919
by JivingDaddy
Replied by JivingDaddy on topic window washers not working
Can you hear a whirring noise of the pump trying to push the water through the nozzles?
If all is silent, it's either the fuse or a knackered pump. Hopefully it's just a blown fuse.
- Skinhead
25 Feb 2013 13:40 #63920
by Skinhead
Replied by Skinhead on topic window washers not working
Just been an had a look, somehow 1 of the pumps has broke, luckily i dont have a washer jet on the rear so ive just swapped the pipes and wires round. I should have looked before i posted this. Its now fixed
- JivingDaddy
25 Feb 2013 13:45 #63921
by JivingDaddy
Excellent news. Can't beat a bit of lateral thinking.
25 Feb 2013 18:03 #63934
by facade
Replied by facade on topic window washers not working
If you are using the rear pump, it will stop working with a fair bit of water left in the tank. The rear pump should be higher up than the front.
