window washers not working
  • Skinhead
25 Feb 2013 18:20 #63936 by Skinhead
Replied by Skinhead on topic window washers not working
facade wrote: If you are using the rear pump, it will stop working with a fair bit of water left in the tank. The rear pump should be higher up than the front.
I better keep it topped up then ;)
25 Feb 2013 23:23 #63984 by facade
Replied by facade on topic window washers not working
The idea is the rear runs out first, so you know that it is nearly empty, or you can't empty the tank with over use of the rear washer, so it leaves a few squirts for the front.
Time to create page: 0.085 seconds
