SWIVEL SEALS
  • Jackdelves
23 Feb 2013 14:19 #63729 by Jackdelves
SWIVEL SEALS was created by Jackdelves
Hello, I'm new to Jimny's, have grease leaking from swivel seal (front passenger side). Is it possible to change the seal without taking all front wheel assembly off? Can I place it over the drive shaft as I notice it has a slot? Any ideas?
  • markyp2000
23 Feb 2013 14:50 #63731 by markyp2000
Replied by markyp2000 on topic SWIVEL SEALS
Only the metal ring has a slot in it the seal dont
Jack it up on that side grab the wheel at 12 & 6 oclock and push and pull it if ypu have play your king pin bearings may be shot if so replace the hole lot look it up in the search section
23 Feb 2013 14:54 - 23 Feb 2013 14:57 #63732 by facade
Replied by facade on topic SWIVEL SEALS
Yes you can, it is in the manual, you slit the seal and keep the slit to the top (or glue with superglue- rubber is the only other thing it will stick apart from skin :cheer: ) but the reason for the leak is your swivel (kingpin) bearings have gone. and the halfshaft is moving in the axle seal, allowing oil to wash the grease out of the housing.
Have a look under info on the home page for how to change the bearings, you can buy a kit from the store.
Edit Mark has beaten me to it whilst my slow fingers tap on the keyboard :)
Last edit: 23 Feb 2013 14:57 by facade.
The following user(s) said Thank You: Jackdelves
  • Muzza904
23 Feb 2013 16:11 #63737 by Muzza904
Replied by Muzza904 on topic Re: SWIVEL SEALS
Dont be daunted by taking off the wheel and other stuff these guys know more than suzuki do and if you download martins how to on kingpin bearing changing then its a doddle. Quick delivery from the bigjimny shop too :)
Sent from my GT-I9300 using Tapatalk 2
23 Feb 2013 19:05 #63753 by fast forward
Replied by fast forward on topic Re: SWIVEL SEALS
yes king pin bearings bought mine from BJ shop . no more leaking grease on the driveway ! :whistle:
if you cant go round it go over it ! or vice versa ?
Time to create page: 0.306 seconds
