OILS
  • adamatdraycott
17 Feb 2013 21:54 - 17 Feb 2013 21:58 #62954 by adamatdraycott
Replied by adamatdraycott on topic OILS
I find 10w-30 difficult to find. Halfords stock it in castrol... Quoted as for motor cycles about £32 for 4L
10w-40 is far more readily available
Last edit: 17 Feb 2013 21:58 by adamatdraycott.
  • nicho
17 Feb 2013 22:04 #62965 by nicho
Replied by nicho on topic OILS
what did you use to put diff oil in.
17 Feb 2013 22:14 #62973 by fast forward
Replied by fast forward on topic OILS
i used the litre bottles of oil with pull out tubes from the neck and squirted it in ! :)
if you cant go round it go over it ! or vice versa ?
  • jonny43
13 Apr 2013 14:35 #68621 by jonny43
Replied by jonny43 on topic OILS
I have changed the oil in the front dif of my Jimny to the 1.1 ltr however its not up to the refill level should it be or is that an urban myth? any help on this would be gratefully received.
  • markyp2000
13 Apr 2013 14:41 #68622 by markyp2000
Replied by markyp2000 on topic OILS
Its should be level withthe filler bung fill it up and let it drain out till it stops then do up the filler plug
  • adamatdraycott
13 Apr 2013 15:41 #68627 by adamatdraycott
I did both front a rear diff las week and they both take atleast 1.5 litres of 80w90
I also used the extending neck on a 1 litre bottle. After covering about 30k mileage, mainly on road the diff oil I fetched out was in perfect condition and I regretted draining it!
Time to create page: 0.106 seconds
